Thin bezel monitor
iZombie_1
Commendable
Oct 18, 2016
13
LG 24MP88HV-S 24"IPS Slim LED Monitor Plzz helpme is this a good monitor it has pretty thin bezel 5ms response time should i buy it
That's the Neo Blade III ? $300.
https://pcpartpicker.com/product/v9rcCJ/lg-monitor-24mp88hvs
The specs are fairly standard. 1080p, 24", LED/IPS, speakers.
It really depends on your preference as to whether you should buy it.
If the thinnest bezel matters the most to you, then sure.
Personally, I'd take something like the ASUS VP279Q-P
https://pcpartpicker.com/product/VkDzK8/asus-vp279q-p-270-60hz-monitor-vp279q-p
A bit more of a bezel, especially on the base - specs are essentially the same, but it's a 27" monitor, and nearly $100 cheaper.
