Thin ITX Build
MKDLMR
65
Hi All!
I'm looking to build a thin ITX system, preferably with an Intel 4600. Can you please tell me what case, motherboard and power supply you recommend?
Thanks!
-MKDLMR
Here are good parts to start your ITX build:
Motherboard: Asus - H81I-PLUS Mini ITX LGA1150 Motherboard ($81.05 @ Amazon)
Case: Fractal Design - Node 202 HTPC Case ($69.99 @ Newegg)
Power Supply: Corsair - SF 450W 80+ Gold Certified Fully-Modular SFX Power Supply ($89.99 @ Amazon)
Total: $241.03
Generated by PCPartPicker 2017-07-02 23:56 EDT-0400
Few words.
MoBo will support any LGA1150 socket Haswell family CPU, e.g i3-4340,
specs: https://www.asus.com/Motherboards/H81IPLUS/
Added a HTPC case to get the thin footprint needed,
specs...
Total: $241.03
Few words.
specs: http://www.fractal-design.com/home/product/cases/node-series/node-202
And PSU is one of the best SFX PSUs on the market today,
specs: http://www.corsair.com/en-eu/sf-series-sf450-450-watt-80-plus-gold-certified-high-performance-sfx-psu-eu
There's also 600W Corsair SF series PSU available if you need more power for your PC.
Though, you can also go with Silverstone ML03 case. ML03 is a bit bigger than Node 202 but with ML03, PSU support rises from SFX to ATX (max 140mm long) and you can install up to 4x 80mm fans into it. Node 202 supports 2x 120mm fans,
specs: http://www.silverstonetek.com/product.php?pid=283
