I am thinking about buying a case for a thin ITX build.
The case comes with an AC adapter and, according to the specs, it is compatible with Intel DH61AG, DH61AGL & DQ77KB plus DN2800MT. These boards have power connectors with an inner diameter of 5.1 mm and an outer diameter of 7.4 mm. I will be using the ASUS N3050T board. It has the same connector.
I messaged the seller of the case. They opened a box and said the case includes an AC Adapter with the model # AD7042. When i look up that part i get Barrel 5.5/2.5mm...
Am i missing something? :/
