So I was using MSI afterburner and I was trying to overclock my graphics card which is a Evga GeForce GTX 950 and I turned the core clock up to +250 bit by bit and the core voltage to like +100 whilst using benchmark Valley, then I started to notice artifacts when I was overclocking and then Valley crashed on me. This scared me so I thought I will just reset the settings on MSI afterburner and when I went to do this my PC shut off to a black screen, so I restarted it and it came back on as normal. I went on to MSI Afterburner again and reset the settings back to default and uninstalled it.
A few days later I realised I was getting major fps drops in every game I played, for example I would have around 250fps on CSGO and it would drop to about 6 fps for like 5 seconds every minute or so, this got me mad so I thought I would reinstalled MSI Afterburner and Valley again. I clocked it to +150 core clock, messed with the core voltage to stabilise it and also turned up the memory clock to about +100. As soon as did that I got a driver error notification on Windows 10 and everything froze then went to a black screen... I turned my PC on to find the automatic repair load up and every time it goes to run diagnostics I get a black screen with only my cursor showing on a low resolution.
Note: When I boot my PC up the GPU fan runs for about 15 seconds and then stops. It seems like it has stopped working.
- I've put the GPU into another system. No luck, it just use's integrated graphics.
