I have the motherboard that comes with the ThinkCentre E93 Desktop and I have since upgraded my computer case to something bigger and better looking. I managed to get everything connected besides the front panel connectors which are very important. The ThinkCentre motherboard is a bit weird in its layout and the ThinkCentre case had a single connector that connects into this pin-out however, my new case has single connectors instead of a single 13 pin + 1 blank connector. My case has a connector which consists of a total of 9 pins.
It would've been simple if the board had a marking indicating what each pin-out is for and which is positive and negative but unfortunately there isn't any of that. At the moment I can't seem to find any information at all with regard to how I should connect this.
I would like to get opinions with regards to which pin goes where.
This is the full specs of the desktop and motherboard
It is basically 7 pins on the top and 6 pins + 1 blank on the bottom row.
______________________
| 1 2 3 4 5 6 7 |
| 8 9 10 11 12 13 X |
| 1 2 3 4 5 6 7 |
| 8 9 10 11 12 13 X |
