[SOLVED] Thinkpad X220 Fan Starts For 5 Secs At Boot Then Stop and Fan Error
adifher
Commendable
Jun 3, 2021
Someone help me, my laptop show notification Fan Error and and can't boot to windows, thanks before
You're advised to disassemble the laptop and then inspect the cooler assembly for any dust and debris, perhaps thee aforementioned gremlins might be impeding the rotation of your laptop's fan blades. You might want to also see if the fan is trying to move when you power up the laptop. You can try and rewove the cooling fan entirely and then give it a clean with a fine bristled paint brush.
I had a similar issue crop up on a Dell laptop, one where the laptop suffered from a horrible power surge, ruined the motherboard. I found that out late after client asked me to replace the fan with a brand new one, replaced with known working fan, no dice after first 5 seconds, then client tells me of the power...
I had a similar issue crop up on a Dell laptop, one where the laptop suffered from a horrible power surge, ruined the motherboard. I found that out late after client asked me to replace the fan with a brand new one, replaced with known working fan, no dice after first 5 seconds, then client tells me of the power surge. Then narrowed down the motherboard to be fired/faulty/glitchy since the fan header was showing the laptop fan to be at 32000rpms, which isn't possible, since the fans blade weren't moving nor was there any noise from the motor.
Latest posts
