The most important questions are:
How many such fans to connect?
What max power (current or watts) does each fan require?
The heart of this is that BOTH of those items are NOT fan HUBS. A Fan HUB gets all power from the PSU via a cable that must plug into a SATA or 4-pin Molex power output connector from the PSU. It gets from the host mobo header only the PWM control signal for 4-pin fans, and thus is not limited by the header's ability. But it ONLY works if you have 4-pin fans.
What you have shown in the Deepcool FH-04 I know to be a fan SPLITTER, and I believe the other one is also. This type of device can work with any fan and header type, BUT all power for its fans comes only from the host mobo header. Virtually all such headers...
