Hello boys and girls.
This Asian PC NOob need some help for next pc build.
I'm trying to build a cool ass budget (around 5k) gaming pc.
I will be playing 1080p resolution and all max setting for any games and I want dat solid 60+ fps no matter what.
Imma fan of RGB so yea...
Q: Will they work?
Q: Is 1000psu enough for RTX 2080 sli?
Q: Will RGB sync together with MB, RAM, GPU with razer stuff
Q: What is the benefits of using SLI?
CPU: Intel Core i9-9900 3.1GHz 9th Gen CPU
PSU: Corsair RM1000X Fully Modular 80+ Gold 1000w Power Supply - CP-9020094-AU
PC case: Lian Li PC-O11 Dynamic Black Case - Razer Edition (Imma razer fanboi)
MB: MSI MEG Z390 ACE Intel 8th/9th Gen Motherboard
CPU cooler: NZXT Kraken X72 360mm RGB Enclosed Liquid Cooling System
RAM: Corsair Vengeance RGB PRO 32GB (4x 8GB) DDR4 3200Mhz Desktop RAM - Black
GPU: MSI GeForce RTX 2080 Ti GAMING X TRIO 11GB GRAPHIC CARD (Imma go SLI)
Accessory: Lian-Li Strimer 8 Pin RGB PSU Extension Cable
Storage: gonna use ma SSD from SAMSUNG
If yall have any recommendations then gimmme.
Thx for de help.
Q: Will they work?
Thx for de help.
