The 6+2pin is not your CPU cable, that is a PCI Express Cable. The CPU cable is an 8pin cable and it is 1 of the 2 cables coming directly from your PSU. The problem is that this PSU is not compatible with your older 4pin motherboard as it is not a "4+4" cable, but an "8pin" cable.
You will need a cable like this
http://www.newegg.com/Product/Product.aspx?Item=N82E16812423185&cm_re=4_pin_Molex_LP4_to_ATX_12V_P4_4-Pin-_-12-423-185-_-Product for this PSU to work with your motherboard.
I hope I have helped you with your problem.
