[SOLVED] This is my system. Are the parts compatible? Any improvements?
Aug 29, 2019
12
Here’s my build:
-Ryzen 3 3200g
-Asrock A320M-HDV Micro ATX AM4 Motherboard
-Corsair Vengeance LPX 8gb DDR4-3000 (2 x 4gb)
-Toshiba OCZ TR200 480gb 2.5” SSD
-EG MN25 Micro ATX Gaming Case
-be quiet! System Power 9 400W 80+ Bronze Certified ATX Power Supply
PC Tailor
Dignified
Herald
The ACPI version is not the BIOS version.
BIOS version will be labelled BIOS or SMBIOS version.
If I have the link correct, yours is here:
View: https://imgur.com/a/u9YQNz3
https://www.morecomputers.com/a?pid=A320M-HDV+R4.0>>ASRock
2.3 is the original board BIOS, so it would need a BIOS update.
You can view the CPU support list here:https://www.asrock.com/MB/AMD/A320M-HDV/index.asp#CPU
View: https://imgur.com/a/Swngep0
It's always best to use this after pcpartpicker to check.
PC Tailor
Dignified
Herald
Welcome to the forums my friend!
What is the overall cost of this system?
Only thing I would mention initially is the A320M needs at least BIOS P4.40 to run the 2200G so you may need to verify it ships with it :)
Aug 29, 2019
12
Thanks for welcoming me. :)
The system costs £283.60 excluding monitor, keyboard and mouse.
I was also worried that my motherboard might need a BIOS update but I’m buying a Ryzen 3200g, so I’m sure this will be supported, right? PC Part Picker says that the 2200g may need a BIOS update but it doesn’t say anything for the 3200g
Aug 29, 2019
12
Looking at the technical specs from the seller (morecomputers.com), the ACPI version under the bios details is 5.1. Is this a problem?
PC Tailor
Dignified
Herald
Aug 29, 2019
12
So how would I go about upgrading the BIOS? I heard that AMD give a free boot kit that includes an Athlon chip temporarily to update the BIOS. Should I order a boot kit?
PC Tailor
Dignified
Herald
You can do yes, it can just take a little while from my awareness: https://www.amd.com/en/support/kb/faq/pa-100#faq-Short-Term-Processor-Loan-Boot-Kit
Alternatively:
  • Find a seller than will ship with latest BIOS
  • Get a motherboard with a chipset made for the 3200G
  • Take it to a repair shop who might have a spare CPU to update the BIOS with.
Aug 29, 2019
12
Having just checked AMDs criteria for the free boot kit, you need to have a X470 or B450 motherboard in order to qualify for the boot kit. I guess I’m stuck with the alternative options.
Aug 29, 2019
12
I've found a solution. CCL offer to update your BIOS for £10 if you buy your motherboard from CCL. Also, I switched my motherboard to a ASRock B450M-HDV so that I can overclock my CPU.
Reactions: PC Tailor
