Question This is on half of my monitor, help!
Jul 17, 2023
So it's been 2 days I have this problem, it came out of nowhere. I was playing gta and realized this weird pixel burn or monitor issue it happens on the screen no matter what I do , play games or watch something or even idle so I'm assuming it's either monitor or graphic card or even the power cable.
https://snipboard.io/dnBXLP.jpg
Although pls help me regarding what might actually cause this issue so I can fix this problem.
Might want to use DDU to remove all GPU drivers, then manually reinstall the latest GPU drivers in an elevated command, i.e, Right click installer>Run as Administrator.
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time?
CPU: AMD Ryzen 5 3500 6-Core Processor 3.59 GHz
CPU cooler: NONE
Motherboard: Gigabyte Technology Co. Ltd. B450M DS3H V2 (AM4)
Ram: 16.0GB Dual-Channel DDR4 @ 1330MHz
SSD/HDD:
931GB Western Digital WDC WD10EZEX-00WN4A0 (SATA )
111GB Western Digital WDC WDS120G2G0B-00EPW0 (SATA (SSD)
GPU: 2047MB NVIDIA GeForce RTX 2060 (NVIDIA)
PSU: Gigabyte P650b 80 Plus Bronze 650 Watts Psu
Chassis:
OS: Windows 10
Monitor: ZOWIE XL LCD (1440x900@119Hz)
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time? 1.5 years
