Thoughts, advice, etc, on my proposed second build?
Renaulter
46
Here's my current list of parts.
http://pcpartpicker.com/user/renaulter/saved/#view=qcyXLk
The CPU cooler might seem a bit odd, but i really like the look of top down coolers. the "jetflo" fan, though loud, is intended to replace the default fan of the CPU cooler.
My main questions:
1) is it unwise to try and make a surround setup without vesa mounts? i intend to buy a massive corner desk just for this.
2) are there alternatives to any of these parts that would save me money without ruining my white on black theme? Monitor's gotta be at least 25 inches, and the bezzle must be tiny.
2) What about this build would you change?
I would really like input on my list of parts before i pour a wackton of cash on this a few months from now. Maybe then, the 1080TI will be out too.
running triple monitors with no vesa is just fine as long as your ok with how they line up good enough for you, but it wont be perfect without vesa mounts, and second, your ssd, you want atl east 100 gb even if its just a boot drive
