Question thoughts/improvement for build
shrey1934
50
Final build:
Ryzen 5 3600
msi b550 gaming edge motherboard
16gb 3600mhz cl16 ram
rtx 2060 super
phantek p400a
crucial p5
corsair txm 550w gold rated psu
any improvements at a similar price point?
logainofhades
Given the cost of that CPU, it would be better to go with an i5 11400.
This Z590 is cheaper than some B560, which is why I chose it. Even with a decent cooler, it's slightly cheaper, than the slower R5 3600 combo. You could possibly save a bit more, going with DDR4 3200 CL16, as well. Intel really doesn't see many gains beyond 3200mhz ram.
PCPartPicker Part List
CPU: Intel Core i5-11400 2.6 GHz 6-Core Processor ($188.99 @ B&H)
Motherboard: Gigabyte Z590 UD AC ATX LGA1200 Motherboard ($209.99 @ B&H)
Custom: Vetroo V5 CPU Air Cooler w/ 5 Heat Pipes 120mm PWM Processor Fan Intel/AMD Universal Socket w/Addressable RGB Lights (V5, Black) ($29.99 @ Amazon)
Total: $428.97
Generated by PCPartPicker 2021-04-30 15:56 EDT-0400
vs
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($251.61 @ MemoryC)
Motherboard: MSI MPG B550 GAMING EDGE WIFI ATX AM4 Motherboard ($179.98 @ Amazon)
Total: $431.59
Generated by PCPartPicker 2021-04-30 15:55 EDT-0400
shrey1934
50
Depends on the price and how much you are willing to work around it.
For example, where are you getting an RTX 2060 Super?
If you can afford it, a Ryzen 5600X is a better option.
already have a 2060 super, and the current build is taking up the budget so any upgrades have to be a similar or lower cost.
thanks
