Hi All,
I'm planning on putting together a pc for machine learning and statistics on a budget of $2,000.
I'm trying to put together a balanced build. Here's the build from pcpartpicker.com.
No incompatibilities were found on pcpartpicker.
The Ryzen 7 3700X should work for my purposes. I need at least 64gb of RAM for using the statistics software R.
I don't do that much deep learning currently, but that could change over the next few years. Does anyone see
any glaring errors? Any advice?
