Im thinking about gammax 200t since i need to replace this asap and im in a local store do you think its good enough?I3-10100F will come with a perfectly adequate stock cooler.
Use the cooler money to buy the non F version which is a good insurance policy in case of a discrete gpu issue.
If you are not gaming, integrated is all you need.
I have used i3-10100 in several builds and found it to be a very quick processor. A very good upgrade over a I7-870.
What is "this" that you need to replace?Im thinking about gammax 200t since i need to replace this asap and im in a local store do you think its good enough?
