Thoughts On Firs PC Build
Mar 13, 2018
32
So I'm going to build a pc and I just wanted to know what your thoughts are on it. There is a i3 8100 with a z 370 motherboard but I'm going to upgrade to a 8600k later.
Systems Specs:
I3 8100-$116
GIGABYTE GTX 1060 AORUS-$350
MSI Z 370 SLI PLUS-$112
HyperX Fury 2x4GB-$105
1TB WD HDD-$45
NZXT S340 White-$62
Corsair 550 Watt Power Supply-$45
Should I upgrade Ram and Get a GTX 1060 3GB Or should I just with what it is.
Cheers!
Thats a tough choice but the difference at 1080p gaming between the 1060 3gb versus the 6gb version is not that much, so I would go for the extra RAM as 16GB does make a difference overall and get the Nvidia 1060 3GB...Just my thoughts. By the way the 8600K is a beast CPU and overclocks so well...(yes I have one) so when you upgrade it will be great.
