Thoughts on my final build?
ImCorrupt
15
This is what I think will be my final build for my new gaming pc. I'm looking for any recommendations or general thoughts about it and how well it will play games. Thanks!
Specs:
Case: NZXT Phantom 630 Windowed
CPU: i7-4790K (4x 4.0GHz/8MB L3 Cache)
GPU: NVIDIA GeForce GTX 970
Memory: 16GB G.SKILL Ripjaws X
Motherboard: ASUS Z97-K
Power Supply: Corsair CX750 - 80 PLUS Bronze
Cooling: Asetek 510LC Liquid CPU Cooling System
Primary Hard Drive: 120GB Kingston V300 SSD
Data Hard Drive: 1 TB HARD DRIVE -- 32M Cache, 7200 RPM, 6.0Gb/s
Get asus z97-A motherboard if you can.
Your psu CX 750W is a poor quality one.Get a good 750w.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438017&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
That PSU has bad quality capacitors in it.But you'll be fine with that.
But i'd still recommend you to go for the one i provided the link of.It's cheaper but is a good performer.
to be honest 16gb of ram is actually quite overkill for games, since most only need 4gb, I would get 8. but if your going to be multitasking get extra ram. also if you can dish out the extra money,the msi z97-gb65 is right now as much as a asus hero and is pretty much perfectly equivalent. but with that gtx 970 you can run games with ease, such as arma, skyrim and so forth.
ya im wanting to stream/make videos so thats why i went with a 16GB. thanks for the input!
