Thoughts on my first/new build?! help with psu!
Passion_1
Commendable
Jun 1, 2017
54
Mobo - ASrock - H370m pro4 micro ATX LGA1151
CPU - i3 8100 3.6ghz
GPU - Gigabyte geforce gtx 1060 3gb mini itx oc
Ram - ADATA - 8gb (2x4gb) ddr4-2400
HHD - Western digital 1tb 3.5
PSU - ??? (ebay, amazon uk, £50 budget)
Case - Thermaltake versa h21 window atx mid tower case
£400 - perform better then the build i mentioned. dont mind second hand but i want the cpu and case to be new. would like to game at 1080p 60fps. ps4 games i currently play, gow, ow, ufc3, farcry5 so not them games on pc but similar, mayb shadow of war, hellblade, crysis etc
not at amazon, but this might work well, too:
https://www.cclonline.com/product/205075/P1-500B-XTFR/Power-Supplies/XFX-XT-500-500W-80-Bronze-ATX-Power-Supply/PSU1262/
the XFX cpus are designed by Seasonic, though XFX puts them together, and 500W is more than plenty, especially for only 35 pounds.
The XT series was made by Shenzhen Ruishengyuan and not Seasonic like the rest of XFX's psus and is best avoided.
Cases
Fractal Design Focus G Front Computer Case with Window, USB 3.0/2.0 and Audio Jacks - Black https://www.amazon.co.uk/dp/B06XQ5JSRR/ref=cm_sw_r_cp_apa_i_4PZ5AbPJP8EYF
Corsair CC-9011086-WW Carbide Series 88R Windowed mATX/Mini-ITX Case for Computer - Black https://www.amazon.co.uk/dp/B01550Y9GA/ref=cm_sw_r_cp_apa_i_bTZ5AbED4W5V4
Cooler Master MasterBox Lite 3.1 Computer Case 'microATX, Mini-ITX, USB 3.0, Window Side Panel' MCW-L3B3-KANN-01 https://www.amazon.co.uk/dp/B071GDSBMN/ref=cm_sw_r_cp_apa_i_6VZ5Ab3VCPQF3
Cooler Master MasterBox Lite 5 Computer Case 'ATX, microATX, Mini-ITX, USB 3.0, Window Side Panel' MCW-L5S3-KANN-01 https://www.amazon.co.uk/dp/B06XYJ6MSM/ref=cm_sw_r_cp_apa_i_MWZ5AbMZ5PQ7V
All the above need a fan adding really.
Cooler Master MasterBox 5 White with Dark Mirror Front Panel Computer Case 'ATX, microATX, Mini-ITX, USB 3.0, Window Side Panel' MCX-B5S2-WWNN-01 https://www.amazon.co.uk/dp/B01F9S3PJU/ref=cm_sw_r_cp_apa_i_g0Z5Ab79Q6M41
Top of your budget but a really nice case , prefitted front & rear fans , Psu shroud.
Pro 4 board will look really nice in this one.
MERGED QUESTION
Question from Passion_1 : "My first/new build"
My cpu supports ddr4 2400 ram and my mobo supports ddr4 2666, will i be able to use the ddr4 2666 ram that i am planning to buy?
I am planning to buy i3 8100 cpu and ASrock H370m pro4 mobo will the cpu and mobo be compatible? whats the difference with the h370 mobo and the z370 mobo?
MERGED QUESTION
Question from Passion_1 : "Thoughts on my new/first build?!"
