Thoughts on The EVGA Supernova 750W Fully Modular 80+ Gold Power Supply?
iGouldy
31
Hi Guys,
Ive been running a Cheap Power Supply in my System since January and am looking to upgrade to the EVGA Supernova 750W Fully Modular 80+ Gold Power Supply. I was wondering if anyone has had any experience with it? its currently on eBuyer for £76.49 Is it worth it? how good is the product and the cables that are supplied with it?
Thanks, Dylan
There are several versions of the EVGA Supernova 750W. Check if it's the G2 Version (EVGA 220-G2-0750-XR) which is highly recommended as it is categorized as Tier-1. On the other hand, if its the NEX G Version (EVGA 120-PG-0750-GR), avoid it as it is categorized as Tier-4.
Tier-1 PSU's are "The highest quality and most stable Power Supply Units available. Protected by industrial grade protection circuitry and can output wattage at a rated maximum temperature of 50°C or below. These units are also Haswell certified, meaning they can cope with the C6 and C7 sleep states of 0.05Amps without triggering the under-current protection switch. May even go over labelled wattage and still work until it safely shuts down."...
Tier-4 PSU's have "No Japanese capacitors found. Only Taiwanese capacitors and may even include Chinese capacitors. Very basic safety circuits or even thin gauge wiring used. Not for gaming rigs or overclocking systems of any kind. Avoid unless your budget dictates your choice."
Here's a full list of PSU models and brands that are highly recommended and that must be avoided.
By the way, what is the current GPU you are running?
Thanks for the Advice i will have to check that.I Believe it is G1, im not to sure. Here is the Link, im sorta new to this
http://www.ebuyer.com/660724-evga-supernova-750w-fully-modular-80-gold-power-supply-120-g1-0750-xr
i'm currently running r7 260x (I know the PSU is overkill but i'm starting to overhaul the system starting with the PSU).
Also Thanks for the Link, Great read.. My current PSU is ranked Tier 4 Ohh Dear
Thanks for all your Help!! I will have a look into that
You can select any of these Tier-1 / Tier-2 power supply units (choose the cheapest and the readily-available in your location):
EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
Antec HCG M 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
SeaSonic M12II 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
SeaSonic G-750 750W 80+ Gold Certified Semi-Modular ATX Power Supply
EVGA SuperNOVA P2 750W 80+ Platinum Certified Fully-Modular ATX Power Supply
Thank You so much for all of your help! really appreciate it
