Hi All,
Looking to upgrade my RAM keeping gaming performance as priority. My PC Specs are as follows
CPU : AMD Ryzen Threadripper 2950x with CM Wraithripper cooler
Mobo: MSI X399 Gaming pro Carbon AC
GPU : Nvidia Zotac RTX 2080 Ti
Memory: 2x16GB DDR4 G.Skill 3200Mhz Ripjaw V-series CL16 Hynix
PSU: Coolermaster V1000 Vanguard 1000W 80+Gold Modular
I am currently running dual channel 2x 16GB @ 3133 Mhz CL16 timings, but the gaming performance isn't that great. 20-30 FPS Drops at times with Hitman 2 & Witcher 3 at Ultra and wanted to upgrade as ryzen performs better with quad channel. My Ripjaws isn't B-Die so not able to push over 3133.
I have read Threadripper/ryzen prefers speed over cas and I am looking at 3600 MHz or more Samsung B-die chips. Worst case I can still configure at 3466 Mhz .
I have gone through recommendations for threadripper all over the internet and came to a conclusion with the below options. Wanted to have a second opinion on what to buy (made a mistake going for ripjaws earlier). Budget is upto 600$ and want a quad channel 4x8GB ram combo.
Option 1:
2 kits of below:
G.SKILL TridentZ Series 16GB (2 x 8GB) 3600 CL15 Model F4-3600C15D-16GTZ (15-15-15-35) @ 440$ (220$x2)
https://www.newegg.com/Product/Product.aspx?Item=N82E16820232306
Findings:
- Samsung B-die but not in my motherboard QVL. Not sure if it can reach 3600Mhz and also if 2 x 2 x 8GB would be fine.
G.SKILL TridentZ (4 x 8GB) 3600 Mhz CL16 Model F4-3600C16Q-32GTZKK (16-16-16-36) @ 399$
Option 2:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820232584
Findings:
- Samsung K4A8G085WB-BCPB B-die as per this review: https://www.tweaktown.com/reviews/8268/skill-tridentz-rgb-ddr4-3600-32gb-memory-kit-review/index.html
- As per a 3D mark benchmark, someone was successfully do 3600Mhz on a threadripper 1950x & ASRock X399 Taichi on this ram (not sure whether my MSI x399 carbon pro ac may get the same love). : https://www.3dmark.com/spy/2340426
- Not in my motherboard QVL but Samsung B-die and with above benchmark is it enough for me to go ahead? Not sure if it can reach 3600Mhz.
Option 3:
2 kits of below:
G.SKILL Trident Z RGB (For AMD) 16GB (2 x 8GB) 3200 Mhz CL14 Model F4-3200C14D-16GTZRX (14-14-14-34) @ 460$ (2x229$)
https://www.newegg.com/Product/Product.aspx?Item=N82E16820232650&ignorebbr=1
Findings:
- Samsung B-Die, Has AMD compatibility and will work at 3200Mhz (Might overclock to 3333/3466).
- Does 2 kits of 2x8 GB will be able to do Quad channel @ 3200Mhz or more on a ryzen?
- Seems overpriced (as it is 3200Mhz only)
Option 4:
G.SKILL TridentZ RGB Series 32GB (4 x 8GB) 3200 CL16 Model F4-3200C16Q-32GTZRX @300$
https://www.newegg.com/Product/Product.aspx?Item=N82E16820232753
Findings:
- Most affordable but not sure if it has Samsung B-Die and can overclock to 3466/3600
I am leaning towards option 1 or option 3 as its 3600Mhz ryzen seems to favor gaming performance but concerned if it would be compatible.
Let me know if you guys have a better suggestion/alternative.
Thanks for the help
Regards.
Option 1:
2 kits of below:
Findings:
Option 2:
Findings:
Option 3:
2 kits of below:
Findings:
Option 4:
Findings:
Thanks for the help
Regards.
