so first i am a mechanic not a pc builder and this is not a pc we a discussing this is a cooling system. this is a hobby/experiment out of my curiosity because I've noticed something in almost all mineral oil pc threads. no one seems to understand that oil is best cooled with water( and to the one who said water is used to cool cars not oil you are wrong water cools the oil) through liquid to liquid heat exchange, and due to the fact that oil can cover more surface area than a water block via heatsink the thermal conductivity factor can be made up for.
that aside the origin of this experiment is i do want a mineral oil pc because of the cool and wtf factor, but why not make it work well to.
the idea now. every mineral oil pc i have seen uses air to liquid heat exchange to keep the oil maintained but because of oils ability to retain the heat it does absorb this is not effective. so my idea (which credit to 4ryan6 to posting the peltier build that is stage 3 of this) is as follows.
first oil cools the pc cycled through a liquid to liquid heat exchanger, second chilled water through the exchanger as well in a cross flow configuration. this means that the coldest water flows in where the coldest oil flows out and the same for the hot sides. third chill the water with peltiers. fyi im not talking about water really more like non conductive coolant with a real low freezing point. a forth stage could be considered to be keeping the hot side of the peltiers as cool as possible since longer runtimes would be better for the cold water and relay thermostats are already planed in this build
the hope is that if the pc i put in this build were to raise the oil to say 50c with out the chilled water. the chilled water could bring it down to in a dream world 25 in reality maybe 30 to 35 c as the maintained temp.
please if your responses are why would you do this. your and idiot or any other trolling keep it to your self i am well aware of the draw backs namely the fact that the plans i already have have me consuming 1 kilo watt an hour when in full operation.
what i am looking for in posting this is constructive criticisms, potential idea on how you would do it and maybe that silent person who has already done this and how it worked and what they would do different. i do have a full build planned out but first im curious what ideas others have and will give more details if interested.
UPDATE: BUILT AND RUNNING.
but sadly with a leak in the bottom of the heat exchanger. it didnt have an impact on cpu temps ove water cooling i have a 6900k overclocked to 4.4Ghz and thats as far as i can get it. stress testing puts it at 64C. gpu temps however it did awsome i have yet to get the gpus over 44C. 2 asus 1080ti strix over clocked to 1757 boost 3.0 to 2063 memory at 11120. and every thing else on the board has seen 15 to 20 degree drops. a samsung 960 pro 2Tb went from 50c to 29.
8 avexir green teslas 2800 c15 are oced to 3000 and went from between 54 and 57 to 31 and 36. all this while the oil never gets over 29C its self.
now if i had enough cooling overhead on the cold water i was going to remove the air coolers and go to water blocks for the cpu and gpu. how ever the cold water get heated to between 18 and 24C. before i put any load it was sitting at 1 to 4C based on ambient. and non of this does any thing to prevent a massive heat output in to the room as i went with the equivalent of 17 140mm radiators to keep the hot water within 30 degrees of 0 the hot water goes from 34 when the thermostat shuts the sytem of to 29 the cycles the peltiers back on. with that amount of 34 degree surface area the system has a huge thermal and physical foot print. the case was built out of aluminum ex and sheet metal and is 800mm by 800mm by 600mm. ill post picture when i can but back to waterblocks. the oil enter thru a port i drilled in the bottom of the plexi tank and exits 3/4 the way up just behind the cpu sucking the hot oil away from the cpu backing area for the mobo. what i may do in the end is change from air coolers transfering heat to the oil is i might just use the oil as an insulator to prevent condensation from forming on the cold water lines by removing the heat exchanger alltogether and use the bottom port to enter the tank under the oil thus keeping air off the lines. i would have loved to do this and keep the heat exchanger but its not working well enough.... it might if i switch ti a 14.4 powersupply since im using 26 amp peltiers at a 20 amps 12vdc off of a ax1200i, but i like being able to monitor the draw off the power supply the way i am.
as for the leak its very slow and manageable since i made a removable drip pan at the bottom of the case and designed the case floor with a bend to flow all liquids to one spot.
so any suggestions on which way i should go first up the power supply or go to mineral oil insulating the cold lines? the tank is holing up very well and has its corners caged by the aluminum ex and the holes have bits power bulkhead pass thrus with double packings to keep it from leaking under the preasure of the oil so im quite confident the will hold up but if cold water is put thru those ports it might shrink the packings and then leak? or even then the cold water might still get heated before it hits the cpu since the oil will then be even hotter. what do you all think?
