I have a Lian Li full size case, and I replaced the two intake fans on the lower part of the front with Gentle Typhoon fans. When both are running, I get a throbbing hum (whoom whoom whoom whoom), reminiscent of the USS Enterprise. If I stop either one of the fans but leave the other running, the throbbing stops. It's only when both fans are running. Pressing hard on the case of one fan or both fans does not modify the sound, so I don't think they're loose (they're both attached with metal screws to the metal frame of the case).
I'm guessing that there is some sort of constructive interference between the vibrations of the fans. Other than permanently turning one off, are there any solutions I should explore? I've already added accoustic padding inside the side panels, and that didn't do much. Taking both side panels off doesn't stop it, so it isn't those panels vibrating, and I've tried pressing hard on every part of the case to see if I could modify or stop the vibrations, but there was no change.
Thanks,
Dan
Thanks,
Dan
