Throttle solution for FX-8320 GIGABYTE 970A-UD3
Blento
4
I've been searching a lot why my MBO was throttling CPU when OC, but I couldn't get the solution.
This is my everyday setup with no throttling.
so however have same problem, check this setup.
I have watercooling, and huge fan directed to MBO.
BCKL Clock control set to 200MHz
CPU NBR i freq - auto
HT link Freq. - auto
CPU CLOCK ratio 23
Advanced CPU core features 4.6 Ghz
Extreme memory - disabled
System Memory Multiplier 6.6..
Memory freq - ¸1332 Mhz
CPU Clock Ratio 23.00
Core performance boost disabled
CPu unlock Enabled
Cool @ quiet disabled
C1E Support - disabled
SVM disabled
CPU core control Auto
Core C6 dissabled
HPC mode - enabled
No, I got it stable on 4.7 Ghz...but it's hot..even with custom water-cooled system.
I just posted this topic cause I've spend many hours researching how to fix throttling problem on this MBO, even with best water-cooled system, and huge fans directed to MBO.
I finally figure it out by myself and open topic if someone has same problem, and not to waste time searching for solution.
