thunderbolt 3 to dvi-d 144hz? (please help!)
hunter27205
Commendable
Sep 17, 2017
17
Hi guys, i recently moved so i had to part with my i5 1060 desktop, instead i got a dell XPS 15 9560, i wanted to keep my monitor as i play overwatch in the grandmaster level and so i need 144hz, is there a way i can use the laptops thunderbolt 3 port, and take an adapter to convert it to dvi-d?? if so please link me the adapter!!!
P.S i need to do this quick as soon my skill rating in overwatch will decay, i have amazon prime so all i need is a working adapter and i can have it next day, Price is not an issue!!!! #=
thank!!!!!
The only thing that might work is a USB Type-C to DisplayPort adapter combined with a DisplayPort to Dual-Link DVI converter, would probably total to $120+. It might be better to just buy a new monitor that has DisplayPort.
But in theory it should work right? price is not an issue, and maintaining 110hz or even 100hz will be good enough,
what if i got a high quality thunderbolt 3 to dual link dvi cable adapter? removing the display port part of it?
Maybe, but likely would be capped at 60 Hz. And they tend to be unreliable in general.
There aren't any Thunderbolt 3/USB-C to Dual-Link DVI converters.
Hi friend, I have the same problem, I have a msi with a thunderbolt 3 and I have a benq monitor of 144hz with a dvi dual link entrance, can you tell me how did you solve the problem?? Best regards, maya
Latest posts
