jared0123 :
My power supply is making a constant ticking sound. Would using wd-40 to stop the ticking sounds be a stupid idea? If so what would be some other solutions. Thank you.
Hi - The preferred method is it still being in warranty, & sending it back for repair/replacement.
If it is not under warranty, what beefy suggests above will work. Only I suggest you bite the bullet
and take it to a PC tech to do it, as simple & staraightfwd as it appears, those caps still hold a
potentially lethal charge. Better off letting someone who does it for a living do it.
