Tiger Direct Barebones Kit Help
It's not bad, but you could do better buying separate components. The i5-2500k is a processor just begging to be overclocked, with a H61 board - this isn't possible. That bundle is basically overpaying for a CPU, and under-paying for a motherboard.
Fill out the template for build advice on this link: http://www.tomshardware.co.uk/forum/261222-13-build-advice and see what builds people come up with.
This months System Builder from Tom's hardware is a fantastic $500 build which I highly recommend you check out: http://www.tomshardware.co.uk/phenom-ii-overclock-graphics-card,review-32280.html
