Hey i was thinking of getting 2x Titan Z's but no review is up about the Titan Z in SLI that shows off the power draw only gaming performance.
I know a single Titan Z draws up to 580watts when max load is on it but is it simple as adding up the watts together ? I've had 2x Graphics cards before and looked at a bunch of Graphic Card reviews especially Crossfire/SLI reviews and almost never the single card when times 2x with the watts a single max load is never really the answer aka the R9 295X2 is 610watts max load in reviews of the single card but when crossfired its just under 1200 watts which if it was added together it would be 1220watts max load which its not
so i cant add the numbers up due to it would be inaccurate i was hoping 2x Titan Z's would use a 1200watt power supple i guess the max out put being 1050watts just a guess but also the build will have a i7 4790K and will over clock it a little have 3x SSD's 3x HDD's 4x 8Gbs 1866 Sticks of ram LED lighting and a Blueray Disc Drive
so i am not sure if all that adds up more then 150watts or not i feel a 1500watt would be a over kill for the system and its air cooled not water cooled
