While my core temps are rising, my distance to TJ Max temps start going down. What does this mean as far as the TJ Max temps are concerned?
TJ Max means distance until your system shuts down to protect itself from temperature. It normally does not get to that because your cpu should throttle before. The higher temperatures lower the distance to TJ Max.
