Tnt2 better than geforce 2 ultra?!!
G
Guest
Guest
Well i recently just bought a winfast geforce 2 ultra to replace my old tnt2 card- i have the new nvidea drivers but when i play counter-strike i have really low fps - it goes down to 4 sometimes, i usually get 4-30 fps, but with my tnt2 i would get 99-10 fps
here are my specs
p3 648
192 ram
win2k
so whats up? my friends are telling me that the card is running to fast for my processor thus lagging the processor and giving me bad fps- BUT CS is the only game with bad fps- my quake 3 runs better and smoother now than with the tnt2
?? HELP!
G
Guest
Guest
are you running CS on directx or open GL? my hunch is htat you need to update to the latest version of directx for win 2k.....quake uses open GL. try switching CS from directx to open GL and see if you FPS goes up. it should.
ignore everything i say
lhgpoobaa
Illustrious
Dec 31, 2007
14,462
Yes. your right. the TNT2 is just plain better than the geforce 2 ultra in so many ways!
1. its cheaper
2. the card is smaller
3. the die size is bigger :)
4. its resale ratio is better
5. overclocking ratio is better
6. its hotter. (i had a fanless one that u could fry an egg on)
7. if it dies it costs alot less to replace
if i think of any more ill let u know :)
These are the holy words of my Hamster.
My Hamster doesnt like sarcasm. He may very well bite you in your hard to reach places!
G
Guest
Guest
Man, there something wrong with your system. But if you really think the TNT2 is better, then I'll swap a AGP 2x TNT M64 32MB (in its box! used in a corperate system that never played games! still with manual and original drivers!) for your Ultra. Then I'd be happy, oops, I mean we'd be happy.
~ The First Formally Rehabilitated AMD Lemming ~
G
Guest
Guest
i usually run cs in open gl - but i did try direct3d and all it did was just make it seem i was in a dream graphics state and everything was blurry - so i went back into open gl-
i think i just need to uninstall my old drivers from my tnt2
