Hi All, I was hoping I could get some advice from the collective knowledge.
I am looking to spec out my own system that will be used as a gaming machine for MMOs and media center. It is important that I can run the MMO on all the highest settings. I am pretty set with specs the one question I am having is this: Should I use a company that can put together the system for me after I spec it out or should I order all the parts and build it myself?
I am very techinical and would not have a problem building the system (alhtough it would be my first) the question is : is it worth my time? Should I use a company like Cyber Power? I am a little leary about having a company build my system because I will not know the quality. Does anyone know of a reputable site that will do this? Or have used anyone that does this?
I just had a baby so my time is limited but I want to make the right choice and get the computer with the specs I have selected.
Any advice would be great
Thanks
Thanks
