Case: CM Storm Scout I
Max card length: 10.6"
Card: Gigabyte Windforce GTX 670 (3 fans, approx. 11" long << LOL)
So the first one fits, barely. The shroud is sticking through an oval hole in the HDD cage.
I have three options, as I see it now.
1.) Buy a case that allows for longer cards. Problem: I just bought the Scout a few months ago, and it can't be returned.
2.) Dremel out a slit in the HDD cage for another Windforce 670. Problem: I don't have a dremel and I'm as handy as a retarded thumbless monkey.
3.) Get a non-matching 670 that is shorter than the Windforce. Problem: I'm not OCD but I don't know how these mismatched, different length GPU's will look.
then you could take out the things from the case and cut into the drive cage. But I would not do it.
