to keep cooling cpu
raj4c9
31
Hai,
AMD 8150fx processor,
AMD radeon HD6670(1GB DDR5),
ASUS M5A97 R2.0,
ZEBRONICS BIJILI 2 CABINET,
SEAGATE 1TB HARDDRIVE,
COOLERMASTER 625W POWER SUPPLY.
THESE ARE MY PC DETAILS.
I HAVE LOT OF WORK ON VFX. I AM SPENDING MORE TIME ON THAT. BECAUSE OF THIS REASON MY SYSTEM IS GETTING LOT OF HEAT I WANT TAKE IT INTO CONTROL HOW CAN I COMPRESS THE HEAT ?.
BY USING CORSAIR HYDRO SERIES COLLERS CAN I COOL DOWN MY SYSTEM OR NOT ?. GIVE ME SOME SUGGESTIONS ..... THANK YOU
Liguid cooling will be a very good choice for major decrease in temps. I recoment H100i as a very good all around liquid cooler . Also good cadse airflow will help on cooling the temps inside the case especially if you choose air cooling instead of liquid ( it will help in liquid cooling also a bit ) . This article might help :
http://www.tomshardware.com/reviews/cooling-airflow-heatsink,3053-7.html
Good all around liquid coolers :
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181032
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103181
( or you try smaller ones of the same series if they do not fit in your case )
Good Air cooler:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608024
Good Cheap air...
First off, don't use caps. It's a royal pain in the a** to read.
Now, what are your temps? Use HWmonitor, SpeedFan, or Core Temp and tell use the temps. Have you overclocked? If you have the stock cooler you really shouldn't be doing that.
Next, i'm assuming you're using the stock heatsink. If you don't intend to overclock, get something cheap like a Hyper 212. That should bring the temps low enough to not be a worry, and even allow for some overclocks.
I personally have a Corsair H100i, which I love to bits. It's a little on the pricy end, but man is it a great cooler. However you'll have to check if your case supports a 240mm radiator.. I tried, but for some reason the Zebronics website is blocked. :/
At the very least it looks like you can support some of the smaller single radiator coolers, such as the H60 or maybe H80.
Good Air cooler:
Good Cheap air cooler :
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
To sum up Liquid cooling with decrease the temps more than air cooling (you decide if worths the extra money). Combine that with good case airflow and you will be good.
