Toggle switches on a power strip?
casemods
810
I often find myself unplugging various items from the power strip because they do in fact use electricity even while off.
Has anyone added toggle switches to a power strip?
Would it be hard?
What voltage/amperage switches would I need?
Could I just go off of the ground or the 110?
there are already products out there which feature a toggle switch on the front side and a plug for your device on the rear. some even come built into computer desks. i would go with this style as you maintain the surge-protection insurance. if you modify your existing power strip you will most likely void the warranty.
