When playing The Division I experience huge fps drops (down to 2 fps) usually when playing with other people doing missions in crowded areas and big chaotic fights.
Recently I updated my GPU, since Can I Run That showed that the shader version of my GTX 780 was outdated and Afterburner told me my GPU was at a constant 100% usage. Therefor I upgraded to a GTX 970 and now Can I Run That tells me the following:
I updated my GPU drivers and even tried CPU core unparking, but I doubt that it will help significantly.
The only thing I can think of now is DX12, which only runs in Windows 10. Might that be the problem here?
Anyone has an idea? Thanks in advance!
EDIT: Btw it doesn't matter the game quality I select. Both on low and high settings I have this issue and I've played around with the settings already.
My specs are:Congratulations, your system passes the Recommended requirements! You should have a great experience running this product.
GeForce GTX 970
AMD FX(tm)-8350 Eight-Core Processor
16GB DDR3 RAM
Microsoft Windows 7 Home Premium Edition Service Pack 1 (build 7601), 64-bit
