SOLVE : Turned down the map details, and fps was normal again! Also try to turn off the "Exclusive fullscreen"
Hello guys. So I have a little problem with the new Tomb Raider. Set everything to ultra, tress fx and fxaa, runs smooth, around 40 is in opened areas, and 50-60 when in a cage, or a more closed part of a map. Seems like everything is allright, and then boom, when getting into the part with the Favelas, and after when I look down from a mountain my gpu usage drops to 50%, fps to 20.. Though something gone wrong, restarted, same, when not looking directly into the "city" I get normal fps, but when I turn to that, fps drops again. So I decided to turn down the settings, going down to medium gives me 30fps, but still 50% gpu usage. When I'm in the forests, or anything else I get a nice fps, with 99-98% gpu usage.. Thought it seems like a cpu bottleneck, started to monitor it, when the gpu is working at 99% my cpu usage is like 45-50% on all 4 cores, when the usage drops, they kinda remain the same, 15% + on some cores, but the overall cpu usage is around 50% in Task manager.
I'll attach some pictures about it:
This is the high settings low usage:
This is the normal 99-98%:
This is the medium:( same spot as the first images )
Here's my specs:
Win8.1 entprise 64bit
Phenom II x4 955 @ 4ghz with a hyper tx3
HiS iceQx 7870 GHz edition
4 gigs of ddr3 1600MHz ram
CM Gx 750W powersupply
Philips 220E ( So I'm playing on FULL HD ) !
ps.: sorry for the phone shots, was too lazy to shoot with fraps 🙁
Here's my specs:
