Tom's Holiday Buyer's Guide 2008, Part 1
  • Thread starter Thread starter Guest
  • Start date Start date
I play on the prior year's model (3007) all the time without any problems. Don't pass up gaming on a 30" display without at least trying it for yourself!
Just a word of warning to anyone purchasing this monitor and wanting to watch Blu-Ray titles on it. If you use DVI as your input it can not display Blu-Ray titles above 1920 x 1080. Now I know this is the native res on the monitor. But HDCP will fail if the monitor's resolution is set any higher than this. This is due to a design flaw in the monitor's chipset. This wouldn't be a problem if all it meant was you had to reset the resolution when you want to watch a movie, but the problem is, 1920 x 1080 is not the same aspect ratio as 2560 x 1600. So your picture is vertically stretched. I know this because I bought one and spent hours in forums and on the phone with Dell before finding this out. I returned the monitor, because at $2000, there's no excuse for buggy HDCP support over DVI.
I think I'd take the 30 inch dell if it was free......Guess I won't be having one now for sure.lol.
8 mills is just to slow.And Leigon thanks for the heads up.
I do hope the new items to come are more interesting than this first round.
What happened to the great girl from last year? The blond on here looks strung out and or too gothy for a Christmas ad.
About the response time, 8ms does seem a tad high but we have to be careful here. Most manufacturers will advertise their monitors as having a 2ms or 5ms response time. However, when you look at the charts, most of the time this response time is the maximum the monitor can reach during a dark scene or a low action gaming sequence. This is often not representative of an average use and the so-called 5ms monitor will most likely be around 6ms-7ms in everyday situations. Same thing applies for contrast since every manufacturer uses their own chart for measuring it. The best way to know how your monitor will perform in real life is to look at comparative charts made by neutral parties, like Tom's, who uses the same methods to compare response time, contrast and color fidelity with all monitors.
As for this particular Dell 3008WFP Ultrasharp 30", I have really no idea if it's suitable for movies and gaming or not. However, is Chris says it is, it's usually enough for me! Unfortunately, I just bought a Samsung T220 and it pleases me enough. Anyway, I do not have 2 grand to put on a monitor... yet.
How do you find The Samsung T220 picture wise and lag?
While not the "perfect" monitor, it's definitely one of the best (if not the best) 22 inches monitor around. The colors are rich and true, the contrast is sharp and I haven't notice any lag at all, although I only play World of Warcraft and watch some Divx. Still, the difference was amazing when I switched my old Philips 19" with it! I'm pretty sure the same quality would apply on a fast-paced FPS or a Blu-Ray HD movie. However, I would recommend the T240 if you intend to use your monitor to watch full HD content. Samsung also offer the same models with HD at the end (T220HD) which has a integrated tuner, if you're into that stuff.
I recently purchased the samsung t260hd it along with the t240hd are a couple of the only ways to get an hdtv with that small of a screen still with 1080p support.
