[SOLVED] Too little clearance between PSU and GPU?
Nov 21, 2020
Just bought a new small form factor system and it seems to me that there's totally inadequate clearance between the GPU fans and the PSU. Am I right to be annoyed?
Edit:
View: https://i.imgur.com/OLl2Rpv.jpg
Hopefully the photo is accessible now. System's a mini-ITX from Scan, GPU is an EVGA 3070, case is Fractal Design Nano S. Feels they should not have been configurable together given the clearance.
Couple things (not fan of how that is stuffed together, BTW). First, you have a bit of "GPU droop" going on. You might be able to wedge the gap between the PSU and GPU to even out the GPU, that will help with additional airflow to the fans.
Be sure to populate both front fan mounts to suck in cool air for the system. This could help as well.
Of course, you could always swap the PSU yourself and keep the original Corsair as a backup.
The image you've include must be the wrong one. I'm seeing a no entry image in the center of your post. If the intention was to shoot us an image of the clearance issue you're speaking of, then you were on the right track. Host your image on Imgur and then parse a link for us to see.
