Question Too many displays, too confused (help choosing a display)
May 14, 2019
11
So i just upgraded to a gtx 1660 ti and now i wanna go for a second monitor to go with my current one, which is not very great (samsung t22c350)
Tho after looking into it im completly lost, i can't find very definitive information about if a gtx 1660 ti can support 1440p, and even if i decide between 1440p and 1080p, theres so many refresh rates and different monitors...
I don't play super demanding AAA games very often, but i do from time to time. Now if my GPU can take 1440p only on less demanding stuff (atleast wallpaper engine, for example, but also mid-range graphics games) , i guess i would just play the more demanding games on my smaller monitor?(I'm gonna call it smaller since my current monitor is only 22" and i would definitely want to go for a bigger one). I think that would work?
I'm not sure about the budget yet since i don't even know if i should be preparing for a 1440p or a 1080p, but it would be somewhere 300-350USD (maybe 400 if there s a really really good deal that i should go for)
Any tips are appreciated seeing as what i read so far on display, it's pretty subjective.
Gmoney06ss
595
84
5,090
13
The 1660ti should be decent for 1440. And the nice thing is you can always just use 1080 On a 1440 Monitor, if not getting the desired frame rates. And if you up grade to a better card in the future, you'll have no need for a monitor upgrade.
I have a Dell s2719dgf. Its a 1440/155hz monitor. 27" and should fit in your budget. I got mine for $360 at best buy, but have seen it as low as $320 On sale. MSI also makes some great monitors, I had an optix 27" 1080/144, curved. It was nice, I just wanted a 1440. It will also be within your budget. Those are the only two I've had personal experience with and would fell comfortable recommending. Prior to that I was just using my tv.
May 14, 2019
11
The first paragraph was exactly what i was hoping to hear :D
And that Dell monitor is looking really good, has a lot of features, and i found it for just 330USD in my local store, so i think i'm going for that one.
Thanks for the help :D
Reactions: Gmoney06ss
