hi, im building a new computer atm, my case (NZXT Tempest EVO) have 5 fans in it, and i cant get them all plugged in on my motherboard (MSI 790FX-GD70) because there isnt enough slots for all the fans on the motherboard? what is i do??
Thanks
First, ask yourself if you really need all of those fans. If it turns out your answer is "yes", then the second thing you should do is connect the fans using either this:
Thanks
