Hello all!
So, as the title shows - I have 3 questions.
I built my computer(4770k(OC@4ghz), 280x and did an Aida64 test and it has a warning icon on a few items.
When I first ran it, it said ym CPU had 1.2000v Voltage and a warning sign, now it says 1.200v.. I set it to 1.36v in the BIOS, because it kept crashing with less than 1.36v sadly.
My temps are probably bad(idle) - as i'm still using the stock cooler, until next week which is when i'll get a nice shiny DH-14, unless there's anything newer/better now a days?
So, the above is two questions in one I guess.
Last question: I have 8gb XMS3 1333 CL9 ram, and a few days ago I decided to buy another set to help with some apps, and hopefully less SSD throttling. I checked a few minutes ago, as it has been dispatched and to my horror I ordered a different one. I ordered XMS3 8GB 1600 CL11..
I currently have my cl9 running at cl11@2000MHZ as it technically is better than 1600@cl9. So. The question is - will I be able to slide the CL11 in and expect to be able to perhaps keep my OC? If not - do you think it could hit 1866@CL11 at least? If so that won't be so bad as it shouldn't be too much worse than 1600@CL9.
Thanks for hopefully replying.
