Top 2011 video card for330max 370 peak power supply
gthomas
Hello,want to know the best video card I can get for my system.
I have a new asis with i7 core 2600, 8gb ram dd3,win 7 64 bit and AC Bell ps max 330w and peak 370 for 30 sec. as read on lable.
What exactly is an asis ? Asus ? What kind of computer comes with a 33ow psu ? With that psu you will be shopping at the bottom of the video card lists. A ,
JATON Video-PX628-DLP GeForce 210 512MB 128-bit DDR2 PCI Express 2.0 x16 Low Profile Ready Video Card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814139060
EVGA 01G-P3-1431-KR GeForce GT 430 (Fermi) 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130609
EVGA 01G-P3-1430-LR GeForce GT 430 (Fermi) 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130579
You may want to consider getting a new power supply , maybe at least a 500w , I don't know what you will be doing with your computer but 300w is not very much when you look at what you have for components.
You have a very nice spec, but you won't go far with the PSU though. The only graphic card that can run with that PSU is Radeon HD 6670. If you upgrade you PSU to 600W-650W Corsair, Antec or Seasonic, you can upgrade to Radeon HD 6870.
thanks for the help. I just installed a conair gs600 and it would not power up. checked connections but could not get it to work. so I put in my old one and it powered right up. guess it might be a dud.
