Top exhaust fan above Ryzen stealth cooler
Oct 4, 2018
21
Hi, I am wondering if I should add a small 80mm fan inside the top of my case above the Ryzen stealth cooler.
I guess I am asking because I don’t want to veer the airflow from cpu fan/heatsink. I don’t want them to fight eachother if they even would.
I was gonna install a nocturno a couple to few inches above stealth cooler as another top exhaust fan. I do have 1 120mm fan installed up there already above my Corsair vengeance LPX ram which is OC.
What do you think?
shmoochie
Notable
May 10, 2018
891
197
I would be worried about putting another fan directly over the ryzen cooler because they will conflict. Are you having temperature issues? If not, it's probably not worth messing with.
Oct 4, 2018
21
No , no overheating.
I’m at 63 /66 degrees C. Running black ops 4 @ 3.4 ghz but if I initiate MSI GAMBOOST on my b450 tomahawk @ 3.9 ghz I’ve reached 76 degrees C. And I don’t think I liked that so I shut off gameboost.
Similar threads
