BudCollector
27
I'm building a new PC. This is what I have so far:
Lian-Li V1200B, ASUS A8N-SLI Deluxe, Enermax noisetaker 600. Going to put a AMD 3500+ 90nm & a Zalman CNPS7000B-Cu LED.
What I'm wondering is if I should go ahead & put an exhaust fan on top now instead of waiting until later. If I have tempature issues.
Any suggestions on what fan to put up top? I was thinking 92mm.
Thanks
folken
2,759
If you want to it will be way easier to do it w/o all the hardware in there. You shouldn't run into any overheating problems (those 120mm fans in the case move a decent amount of air) but if you are paranoid about temps go for it.
I'm only using the 120mm intake and exhaust fans in my 1200b and it stays at fairly decent temps. My system isn't nearly as powerful as that one but I've go so much crap stuffed in mine I'm surprised I don't have heat problems, lol.
<A HREF="http://www.folken.net/myrig.htm" target="_new">My precious...</A>
