So I am finishing my build and I really cant decide what cooling setup to go with. My CPU cooler is a massive R1 Ultimate that blocks pretty much the entire upper mobo area , while my GPU is a R9 390 which does run pretty hot, so I really need a good cooling setup. I am going to put a 140mm Cryorig XF or a Thermalright TY141 on the front panel, and another 2 of them on top. But as you can see in the picture below, theres really no point in putting an intake fan above my CPU cooler since it totally blocks the way. The way I see it, the "back" top fan should be exhaust and the "front" top one intake. THis way one of the fans would blow air directly on my CPU intake and GPU, while the other fan would help remove the heat from the case. But is it a good idea to have 1 intake and 1 exhaust fan next to each other? ( It goes without saying that I have a 120mm exhaust fan on the back panel)
http://imgur.com/KKX4HsK
