Tosh no power
Linda_6
What colours are the 3 led lights when power to the computer is working properly on my Toshiba satellite c-50.
Hi,
Please do try and do a hard reset first, remove the battery and AC adapter then press and hold the power button for 20 seconds. Plug just the AC adapter then try to boot the laptop again. If it doesn't boot up and there's still lights on your laptop try and hook up an external monitor and see if you''ll see any display because if you do there might be something wrong with your built display or the ribbon cable connecting the LCD to the motherboard.
Hi,
