Toshiba C55 will not start yellow LED blinks 4 times
Toshiba C55 satellite will not power on. When you hold the power button the yellow LED blinks 4 times
I think it is your charger or battery going bad.
First, try a reset. Remove battery and from AC. Press and hold power on button for 30secs at least. Put back battery back and plug into AC then Power ON as normal.
If that does not help, try it with AC only (remove the battery) or the other way around.
