Toshiba C660-115 wifi problems
cpu2007
12
Hello everyone
I am having an issue with this mode.
I have installed the wifi lan indicator drivers and other drivers as well but I'm not being able to turn on the wifi.
I'm not sure whether the problem is the the hotkeys,drivers or something else.
If I press fn+f8, nothing happens so after some search, some people suggested to install the value added package for my model; I installed it but this causes all the hotkeys not to work(brightness,sound,touchpad) and they work when I unistall it.
Any advice on how to enable the wireless?
Thank you
Look in Device Manager for any clues as to the status of the wireless device driver under "Network adapters".
If there's no such device listed there and neither are there any errors shown in there, it typically means the device is dead so it isn't being detected.
