Toshiba DVR remote won't work.
Aug 18, 2018
I have a DR430KU Toshiba DVR. It still works, but the remote will not control it any longer. I recently switched to an Over-The-Air antenna. Could this be the problem?
If you can control DVT functions with unit's button - it will be a problem as long as there's a function accessible thru a remote only. CHeck cheap remotes at Dollar Store, Walmart etc, whether they support your DVR. As a last resort, universal remotes can be had for under $50.
