[SOLVED] Toshiba dynabook Satellite Pro L50-G-14L BIOS Legacy Boot Mode
tasaras98
26
Hello all, i recently bought the above Laptop Toshiba dynabook Satellite Pro L50-G-14L.
I want to install Windows 10 Pro, but this Laptop has Windows 10 Home, so i disabled Secure Boot, and then i wanted to change UEFI to Legacy Boot, so i will boot my USB Stick to install Windows 10 Pro.
Unfortunately, i can't find anywhere in the BIOS the setting to change Boot Mode, like this setting doesn't exist. Is there any possibility?
Can someone help solve this problem?
Thank you.
Try pressing and holding "F12" when Toshiba splash-screen appears.
That should bring up the "one time" boot device selection screen without messing with the BIOS settings.
It was "F12" on my Tosh Satellite anyhow, should be same on yours. I never messed with the BIOS settings on any laptop, no need to if it has a boot menu.
