Got a toshiba p200d 143 on vista and was going slow alot and kept crashing. Used pc recovery cd. And so it worked. Now i cant connect to my bt homehub but it works through a ethernal cable. But wireless dont keeps saying limited connectivity. Iv done what the troubleshoots done moved the hub box. Reset ip address reset area connection. Turnt labtop off an on. Made sure the Lan switch is on. Turnt wifi on off reset. And still just wont connect. Iv tried goin on device manager to see if any updates. And says none says wireless is working properly. Iv tried using command prompt but didnt get anywhere. Someone give me steps to do it. Many thanks
